My standard works 99% of the time login code is performing fine on most machines. However I have this one machine that fails first attempt with the following error report, but the second attempt (which prompts the user for credentials, the same credentials used on first attempt) succeeds. The oddity is the error. Why is it trying to compare a version 1.0.0.0???? This is 2017, I have no code or dlls at version 1.0.0.0. I think this may be a 'default' version number being sent in erroneously.
System.Exception: InvalidServer
1.0.0.0 is not compatible with the following applications on CADServer:
Vault Basic Server 22.1.2.10
Vault Workgroup Server 22.1.2.10
Vault Collaboration Server 22.1.2.10
Vault Professional Server 22.1.2.10
Has anybody seen this before.
Hi Jamie,
I am able to recreate the behavior where the first time I log in I get a license error but when I try it again the error does not occur and I get a connection. I am using the ItemEditor SDK sample. It uses this code to log in:
VDF.Vault.Forms.Settings.LoginSettings settings = new VDF.Vault.Forms.Settings.LoginSettings();
VDF.Vault.Currency.Connections.Connection connection = VDF.Vault.Forms.Library.Login(settings);
I am not seeing the InvalidServer error yet. Can you share your code that is getting that error?
Wayne
When accessing vault I use the VaultConnection property to lazy-load vault. So the first point of access is my private variable vConnection, and determining if it exists, is logged in, and can be logged into and out of. My newest log into vault command offers the user a chance to change the login variables, but defaults to the same credentials otherwise. For the user in question, the first auto attempt throws an error, and the second manual attempt succeeds. Same login command either way.
Shared Property VaultConnection As Vault.Currency.Connections.Connection Get If vConnection Is Nothing Then vConnection = LoginVault() 'vConnection = Vault.Forms.Library.Login(Nothing) If vConnection Is Nothing Then MsgBox("You must log into vault to continue.") RaiseEvent Shutdown() Return Nothing End If End If If vConnection.IsConnected = False Then vConnection = LoginVault() 'Vault.Forms.Library.Login(Nothing) End If Return vConnection End Get Set(value As Vault.Currency.Connections.Connection) If value IsNot Nothing Then vConnection = value End If End Set End Property Public Shared Function LoginVault() As Vault.Currency.Connections.Connection Dim sec As Security = Security.Instance Dim strVaultServer As String = sec.VaultServer Dim strVault As String = sec.VaultVault Dim strUser As String = sec.VaultViewerUsername Dim strPassword As String = sec.VaultViewerPassword Dim lgResults As Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn(strVaultServer, strVault, strUser, strPassword, VDF.Vault.Currency.Connections.AuthenticationFlags.ReadOnly, Nothing) If lgResults.Success = True Then Return lgResults.Connection Else Dim strErrorMessages As String = String.Empty For Each ErrMsg As KeyValuePair(Of Vault.Results.LogInResult.LogInErrors, String) In lgResults.ErrorMessages strErrorMessages += Vault.Results.LogInResult.LogInErrors.GetName(GetType(Vault.Results.LogInResult.LogInErrors), ErrMsg.Key) & vbCr & ErrMsg.Value & vbCr Next MsgBox("Unable to log into vault." & vbCr & strErrorMessages) Dim ehLogin As New ErrorHandler(New System.Exception(strErrorMessages & strVaultServer & " ; " & strVault & " ; " & strUser & " ; " & strPassword)) ehLogin.QuietlyHandleIt() Try If MsgBox("Attempt manual login?", MsgBoxStyle.YesNo, "Vault Connection") = MsgBoxResult.Yes Then Dim conn As Vault.Currency.Connections.Connection = Nothing conn = LoginVaultManually() Return conn End If Catch ex As Exception Dim eh As New ErrorHandler(ex) eh.HandleIt() End Try End If Return Nothing End Function Public Shared Function LoginVaultManually() As Vault.Currency.Connections.Connection Dim sec As Security = Security.Instance Dim strVaultServer As String = InputBox("Vault Server", "Log Into Vault Manually", sec.VaultServer) Dim strVault As String = InputBox("Vault", "Log Into Vault Manually", sec.VaultVault) Dim strUser As String = InputBox("Vault Username", "Log Into Vault Manually", sec.VaultViewerUsername) Dim strPassword As String = InputBox("Vault Password", "Log Into Vault Manually", sec.VaultViewerPassword) Dim lgResults As Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn(strVaultServer, strVault, strUser, strPassword, VDF.Vault.Currency.Connections.AuthenticationFlags.ReadOnly, Nothing) If lgResults.Success = True Then Return lgResults.Connection Else Dim strErrorMessages As String = String.Empty For Each ErrMsg As KeyValuePair(Of Vault.Results.LogInResult.LogInErrors, String) In lgResults.ErrorMessages strErrorMessages += Vault.Results.LogInResult.LogInErrors.GetName(GetType(Vault.Results.LogInResult.LogInErrors), ErrMsg.Key) & vbCr & ErrMsg.Value & vbCr Next MsgBox("Unable to manually log into vault." & vbCr & strErrorMessages) Dim ehLogin As New ErrorHandler(New System.Exception(strErrorMessages & strVaultServer & " ; " & strVault & " ; " & strUser & " ; " & strPassword)) ehLogin.QuietlyHandleIt() End If Return Nothing End Function
