When I try to add a job through Ilogic my result is Job param error.
param1.Name = "EntityClassId"
param1.Val = "FILE"
param2.Name = "EntityID"
param2.Val = File.Id.ToString
param3.Name = "FileId"
param3.Val = File.Id.ToString
askvault.JobService.AddJob("Autodesk.Vault.DWF.Create.ipt", "DWF Create: Name " & cfn.Name & " , ID " & CFN.Id, New AWS.JobParam() {param1,param2,param3}, 2)
Can someone let me know what the format of the parameters need to be?
Solved by Markus.Koechl. Go to Solution.
Hi
There's a good example in the "Vault-Job-Processor---iLogic-Extension" by @Markus.Koechl
You'll find it here - https://github.com/koechlm/Vault-Job-Processor---iLogic-Extension/tree/2024.1
Look in the iLogicJobAdmin.cs file - https://github.com/koechlm/Vault-Job-Processor---iLogic-Extension/blob/2024.1/Autodesk.VltInvSrv.iLo...
Hope this helps
Nick
Nick,
Thanks for the tip. It seems to tell me to do what I am already doing, so no help. Since I am getting an error using the Job Parameter values, I have I was hoping someone could let me know what the parameters need to be or the order they need to be in or something. Sometimes this guessing is frustrating, and it would be nice to know where the answer book is rather than trying different samples hoping that one will be just correct enough to work.
Hi @kenhoff,
Adding Autodesk default jobs to the queue is not a published and documented API procedure. However, we know it is a practice in the community to analyze the job queue in debug mode and review the parameters. This thread describes how to do it.
Thanks for that information. Looks like the answer is Its not supported. Too bad seems like it would be helpful to use. I'm going to see if I can follow your directions to divine what I need.
