I made a custom executable that search Vault for some IDW, checked-out them when found, do something and finally checked-in: when I did the checkout I read childrens (IAM\IPT) and then attach the sames whend I check in.
In Vault all seems ok: I saw IAM\IPT attached to the IDW and also viceversa: IDW version is the last one, that I modify with my application.
If I open the IDW in Inventor I could see and open the rigth IAM\IPT associated as I see them in the Vault panel inside Inventor: also it works if I open the IAM\IPT and then use the "open drawing" (with the IDW already on my local disk).
I get an error only when I open the IAM\IPT and then use the "open drawing from vault" (IDW not on my local disk).
I tried also to use fiddler to see calls and seems correct as the IDW that Vault addin tries to open is the rigth version but it gives me an error: I tried also to "refresh attachments" in Vault but the error is still present.
any idea?
