I am a noob and trying to use C# to programming the Vault(2020 pro) from Markus Koechl with link and show up the error like pic.
Could anybody know how to fix this issue?
Any Comment would help!
Thank you!
https://github.com/lycheex0/Vault-Sample---InventorExportAnySampleJob
The Job is an extension to the Job Processor Host and cannot run standalone. Build the project and attach it to the required processes for debugging. The AU class documentation Autodesk Vault 2020—Programming 101 shares step-by-step instructions on how to do this and lists the two processes (Slide 51) you need to attach to. I hope this helps to get you started.
Hi Markus,
Thank you for reply my question. I was following this class step by step and I managed to get the templates on the right place and open them in visual studio. The problem is that I already get an error while logging in in the Vault while using the template when I try to connect with Vault client (icensingAgent mLicAgent = LicensingAgent.Client) I don't have tis error when I try to log in with "nothing". the specific error I get is "Autodesk.Connectivity.Webservices.VaultLicenseMismatchExeption." I was searching aroud, but I don't find a solution.
Kind regards,
Daniel
