How to get Previous and Next version of File using Vault WebService API
I am using AutoDesk Vault basic 2014 .
Let's say we have one file abc.ipt checked in to Vault and it has 5 versions (Not Revision).
Using VDF.Vault.Currency.Entities.FileIteration I am getting EntityIterationId, means ID of current file. So is there any method which will give us File.id of its next versions and previous versions ( or FileIteration instance of next and previous version)
For example, if we will have ID of 3rd version then we need IDs of its previous version 1, 2 and next version 4, 5 .
Thanks In Advance.
I found solution myself . Hope it will be useful for other users:
You need Master Id of the file and using following API you can find all versions of the file.
File[] fileVersions = connection.WebServiceManager.DocumentService.GetFilesByMasterId(MASTER_ID);
Here MASTER_ID = File Master ID.
Thanks, this helped me.
