Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Getting Vault connection from Inventor Vault login
2 REPLIES 2
felix.bausemer
338 Views, 2 Replies
Hello everyone,
I have the issue that I need to read the connection status (or even better the "Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections.Connection" object itself) from the current Inventor context. The real problem is that I can connect to the Vault from my plugin but Inventor does not recognize if I do so and changes its UI accordingly. So I thought I may be possible to just let the user login the usual way to the Autodesk Vault and I use the "Connection" object that is being created in that process. But I do not know where I can find it. Do you have any suggestions how I can connect my plugin and Inventor to the Vault in one go?
Thanks in advance.
Labels (3)
2 REPLIES 2
zy19860604
in reply to: felix.bausemer
You can see the AU2023 class.
https://www.autodesk.com/autodesk-university/class/Breaking-into-the-Vault-iLogic-Edition-2023
I think it will solve your problem.
felix.bausemer
in reply to: zy19860604
Yes, it helped. Thank you very much.
