Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
File name based on folder structure
2 REPLIES 2
andrea_camisassaC59DC
187 Views, 2 Replies
Observer
Observer
we recently started using Vault Professional and are looking at implementing file names.
I would like to have the option of giving file names based on the structure of the folder.
For example, let's say you have a folder structure like:
- COMM
-- 2022
--- PIPES
I would like for all files located in the pipes folder to have this name: "COMM22Pnnn"
which would be: first 4 letters of the main folder, last 2 letters of the second folder, first letter of the third folder, a progressive number of 3 letters (this number could be manually assigned)
This was easily doable in my previous file management software so I would think it should be doable in Vault?
Thank you for your help.
- COMM
-- 2022
--- PIPES
Tags (2)
2 REPLIES 2
CGBenner
@andrea_camisassaC59DC
Welcome to the forum!
I do not believe this can be done right out of the box.  It will probably require some custom programming, if it is possible at all.  I will move this post to the Vault Customization forum.  Maybe someone there will have an idea.  Good luck!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Chris Benner
Nick_Hall
Hi Andrea
It's worth looking at Vault Data Standard. I don't think it will work out of the box, but the amount of customisation will be less than any other way I can think of
https://help.autodesk.com/view/VAULT/2023/ENU/?guid=GUID-5030830E-69F8-4A57-ABE4-D1D430C58F95
Hope this helps
Nick
Hi Andrea
Hope this helps
Nick
