Hello!
I successfully installed the Vault add-in for Office (Vault Pro 2018, Office 2016): in Word & Excel, there is now a tab Autodesk Vault.
I then tried to install the Data Standard add-in for Office (Data Standard 2018_3): in Word & Excel, there is no tab Data Standard.
1) Should there be a tab Data Standard in Word & Excel?
If yes, I surely missed a step: what is the installation procedure?
If no, when saving a file, how is fired the GUI defined by FileOffice.xaml?
2) After associating Categories/Properties and mapping Templates/Vault properties in Vault,
-in Word, it is possible to insert a field bound to any file property.
-in Excel, how to fill a cell with any file property? Are there dedicated Excel formulas? Should the cell filling be performed using some VBA code? If so, an Excel file, checked in Vault, and containing cells refering to the file properties, can only be under Macro-Enabled format (.xlsm), if the properties are intended to be updated along the file life?
Thank you for your lights,
Best regards.
