I’m trying to log in to Autodesk Vault using the VDF (C# .NET API).
I created an API-Onboarding-ConsoleApplication (template provided by Autodesk), and it works fine there.
However, when I implement the same login logic inside another CAD application’s API, I encounter an exception during the login process.
Has anyone faced this issue before or knows the correct way to handle Vault login in such scenarios? Any guidance would be appreciated.
