Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Customize data standard
1 REPLY 1
sergio.scaffeo
233 Views, 1 Reply
I wanted to know if it is possible, based on the prefix of my code, for the saving path to be positioned in the same folder with the prefix name of the code. For example, if the code starts with STD, the saving path would be C:\vault\std, and if the code starts with ENG, it would be C:\vault\eng. Can you help me with this?
Tags (1)
Labels (2)
1 REPLY 1
It is possible, but I'd like to clarify: your goal is to remove the folder selection (breadcrumb, first row) and auto-select the path based on the numbering scheme's result, right?
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
