Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
changing the title of an item
2 REPLIES 2
tdQ893E
306 Views, 2 Replies
tdQ893E
i need to change the title of existing items using the api. when i try the ItemService.UpdateAndCommitItems command my title stays the same?
setting the item.Title also does nothing
2 REPLIES 2
Nick_Hall
in reply to: tdQ893E
Nick_Hall
Hi
This is some code I use to update Item Title & Description - it's in PowerShell, but it's very similar to C# so it should make sense
$vItem = $vault.ItemService.GetItemsByIds(@( $resultitem.Id ))[0]
$itemRevIds = @($vItem.RevId)
try {
  [Autodesk.Connectivity.WebServices.Item]$vaultItem = $vault.ItemService.EditItems($itemRevIds)[0]
  $vaultItem.Detail = $catalogDescription
  $vaultItem.Title = $catalogTitle
  $vault.ItemService.UpdateAndCommitItems(@($vaultItem))
  Write-Output 'Item Description/Title Update: Success'
catch {
  $vault.ItemService.UndoEditItems(@($vaultItem))
  Write-Output 'Item Description/Title Update: FAILED'
Hope that helps
Nick
Hi
try {
catch {
Hope that helps
Nick
tdQ893E
in reply to: Nick_Hall
tdQ893E
Great this solved my problem, didn't know i had to call edit items into a new item
