Change Vaultbrowser theme in Inventor
christian_skare
christian_skare
Not sure if this is a Vault or Inventor coding issue, but I'm making an addin for Inventor that opens a VaultBrowser.
How can I recolor this control?
       ' Create the Vault Browser control
       vaultBrowser = New ThemedVaultBrowserControl()
       vaultBrowser.Dock = DockStyle.Fill
       AddHandler vaultBrowser.EntityDoubleClick, AddressOf VaultBrowser_EntityDoubleClick
       Me.Controls.Add(vaultBrowser)
       Dim themeName As String = Invapp.ThemeManager.ActiveTheme.Name
       If themeName = "DarkTheme" Then
           vaultBrowser.BackColor = Drawing.Color.FromArgb(59, 68, 83)
           vaultBrowser.ForeColor = Drawing.Color.White
       Else
           vaultBrowser.BackColor = Drawing.Color.FromArgb(245, 245, 245)
           vaultBrowser.ForeColor = Drawing.Color.Black
I'd really like the colors to match Inventors color theme,
Markus.Koechl
There is a basic approach setting back- and foreground colors like this:
if (PlmDockableWindow == null)
	PlmDockableWindow =
		userInterfaceManager.DockableWindows.Add(clientId, Options.InternalName, Options.WindowTitle);
try
	UserControl = new InvAddIn.Forms.mDockWindowChild(app.ActiveColorScheme.Name.Replace("Theme", ""));
	DockableWindow.AddChild(UserControl.Handle.ToInt64());
	var backgroundColor = app.ThemeManager.GetComponentThemeColor("BrowserPane_BackgroundColor");
	var color = System.Drawing.Color.FromArgb(backgroundColor.Red, backgroundColor.Green,
		backgroundColor.Blue);
	UserControl.BackColor = color;
	UserControl.Show();
An individual license of the DevExpress libraries makes applying the full theme colors to any control easier. I recently published an Inventor Addin implementing an iLogic-Vault panel here. Having a license allows you to derive the full Vault theme to any control without coding.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
christian_skare
Thanks for the reply Markus.
The code doesnt seem to do anything sadly, so I'm afraid I need to live with it in light mode, unless someone spot a mistake or a workaround.
Its just mildly annoying, so it doesn't justify the lisence cost of the DevExpress.
    Private Sub InitVaultBrowser()
        vaultConn = GetConnection()
        If vaultConn Is Nothing Then Exit Sub
        browserControl = New ThemedVaultBrowserControl()
        browserControl.Dock = DockStyle.Fill
        navModel = New ViewVaultNavigationModel()
        Dim propDefs = vaultConn.PropertyManager.GetPropertyDefinitions(Nothing, Nothing, Vault.Currency.Properties.PropertyDefinitionFilter.IncludeAll)
        Dim browserConfig = New VaultBrowserControl.Configuration(vaultConn, "AttachmentsConfig", propDefs)
        browserConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.FileStatus)
        browserConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.EntityName)
        browserConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.Revision)
        browserConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.Comment)
        browserConfig.AddInitialColumn(Vault.Currency.Properties.PropertyDefinitionIds.Server.CheckInDate)
        browserConfig.AddInitialSortCriteria(Vault.Currency.Properties.PropertyDefinitionIds.Server.CheckInDate, True)
        browserControl.SetDataSource(browserConfig, navModel)
        Dim themeColor = Invapp.ThemeManager.GetComponentThemeColor("BrowserPane_BackgroundColor")
        Dim backgroundColor = Drawing.Color.FromArgb(themeColor.Red, themeColor.Green, themeColor.Blue)
        browserControl.BackColor = backgroundColor
        browserControl.Update()
    End Sub
Markus.Koechl
It should work if you derive the colors not from the new browser (this is your target to re-color), rather than another Inventor default control. The Vault 2026 SDK HelloWorld sample shares the principle of reflecting the themes without using third-party libraries; it is possible.
Markus Koechl
