VDS customize: skip vds dialog
rom-8754
rom-8754
I am new to Vault Data Standard and currently learning through this tutorial.
As explained in the article, I have modified the Inventor.cfg file to skip the VDS dialog for imported files.
When I import an assembly STEP file, the VDS dialog is successfully skipped for the top-level IAM file.
However, the dialog still appears for the child IPT files, since the custom iProperty "Sending System" is not included in those files.
What I would like to achieve is as follows:
  • Display the VDS dialog only for the top-level IAM file.
  • If the IAM file belongs to a specific category (e.g., Purchased), skip the VDS dialog for its child IPT files.
Does anyone have any suggestions on how to implement this?
Thank you in advance for your support.
Markus.Koechl
You can review here how to implement a handler skipping the dialog. However, you need to determine the criteria your imported files provide.
I hope this helps you proceed once you have identified an available condition in your data.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
rom-8754
Thank you very much! this has been really helpful for me.
My understanding is that if $global:mSkipVDS = $true, the VDS dialog will be skipped, and the key point is how to determine when to set this parameter.
Could you provide some advice regarding the logic for this?
I have come up with a few possible approaches:
- If the category name of the parent IAM file is “Purchased,” set the skip parameter.
- If the file is an IAM and its BOM structure is “Purchased Parts” (or something other than “Standard”), set the skip parameter.
I would appreciate any suggestions or insights you might have on this.
Thank you.
