Vault Customization
Share your knowledge, ask questions, and explore popular Vault API, Data Standard, and VBA topics related to programming, creating add-ins, or working with the Vault API.
Change order general tab modification
1 REPLY 1
Tony_Yates
171 Views, 1 Reply
Tony_Yates
Hi Guys,
Is it possible to modify the change order general tab?  like adding a tick box before it can change state?
Cheers,
Tony
Hi Guys,
Cheers,
Tony
1 REPLY 1
Markus.Koechl
in reply to: Tony_Yates
Markus.Koechl
ECO follows the general principle; we cannot modify default tabs but replace or add tabs. You could use a custom property if your "tick box" should work as a condition. Vault 2023 implemented the support of property constraints, so you get at least a compliance control. You will need an event and restriction handler implementation if you target to restrict a state change.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Markus Koechl
