- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
We're transitioning to Vault Professional along with a new ERP system, which gives us an opportunity to refine our workflow. We already have a custom VDS configuration that allows us to categorize parts using dropdown selections. Now, we want to implement a similar workflow for creating library parts.
The challenge we're facing is that library parts can't be checked in directly since they are outside the working folder. In the past, we first saved them in the working folder and then manually moved them to the correct library folder. While this method works, we’d like to automate the process as much as possible—especially since our dropdown selections already determine the correct library folder path.
I attempted to automate this using an iLogic rule and the AddFile Vault function, but as documented, this approach does not preserve relationships.
I’m curious to hear how others have tackled this workflow issue. Any insights or suggestions would be greatly appreciated!
Kind regards,
Thomas
