Web Service Manager with Windows Authentication
Hi Everybody,
I'm using SDK Autodesk Vault 2017 for develop an ASP.NET application in C# throught web service manager, but I have some issues, I need that users connect to application with Windows Authentication and I found two instances: WinAuthServices and WinAuthCredentials, so my doubt is which I need to use or what configuration I need to follow to establish connection with Vault.
Kind Regards
Jonathan
psaarloos
Hi Jonathan,
Best way to get a connection to Vault is by using the ConnectionManager. The LogIn method just needs a server and vault name in case you are using Windows Authentication. (username and password arguments are ignored).
using VDF = Autodesk.DataManagement.Client.Framework;
VDF.Vault.Results.LogInResult result = null;
result = VDF.Vault.Library.ConnectionManager.LogIn(server, vault, string.Empty, string.Empty, VDF.Vault.Currency.Connections.AuthenticationFlags.ReadOnly | VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, null);
The LogInResult object has a Connection property of type 'VDF.Vault.Currency.Connections.Connection'. From there you have also access to the WebServiceManager which provides access to the low level Web Services API, which exposes 100% of the vault server functionality.
Hope this helps.
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
