VDS-Sample-Configuration-2023 -Error reading last used folder info
Paula.N
Paula.N
Hi all,
have a problem with 1 Client, other machines working well with the same Data Standard configuration.
By safing in Inventor i get this message: "Error reading last used folder info". Bread crumps are empty.
Inventor 2023.3 / Vault 2023.3
Have no idea what's the problem.
Pls help
Paula
Markus.Koechl
Check that this path and file exist in the roaming user profile for this client/user: C:\Users\<username>\AppData\Roaming\Autodesk\DataStandard 2023\Folder2023.xml. VDS for Inventor creates the file on the first login.
We fixed an issue in the sample's initial release that this file copied to the previous version folder ...\DataStandard 2022\Folder2023.xml. Due to this, new machines that didn't have 2022 installed before did not work. The latest VDS-MFG-Sample release 2023.3 includes this fix and other enhancements.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Paula.N
Hi Markus,
thx for reply.
This folder exists on the user roaming Folder as expected.
VDS-Sample-Configuration is at 2023.3.
Dont' know what to do next.
