VDS per Vault?
VDS per Vault?
mchi_topsoe
VDS per Vault?
mchi_topsoe
Getting into the Vault Data Standard (VDS). Very powerful extension!
Can I make the menudefinitions.xml Vault specific?
We have different setups for different vaults. (Different properties). I want to push the same configuration to all users.
Markus.Koechl
You cannot switch configurations per login, as the configuration loads during start-up. However, you can evaluate the Vault name to switch your business logic within the scripts and UI (XAML) styles.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
mchi_topsoe
ok, so the menu modifications will be the same for all users.
I guess this is something for the Ideastation.
Thanks for the reply Markus.
Markus.Koechl
Yes, the menu definition applies to any Vault to which the user is logged in. You can submit an idea; however, I fear we cannot follow-up on this: the Vault Client would need a restart, as menu customizations are loaded during the application start-up. The problem is the order: the host (client application) starts and loads the VDS add-in with all its configuration parts (including the menu definition, as the client needs this information during start-up). The user logs in, and with that, the selection of a Vault.
Markus Koechl
mchi_topsoe
Thanks for explaining - that makes sense.
So we can add the menu item, and do the validation in the script upon execution.
/Michael
Nick_Hall
Hi Michael
I read @Markus.Koechl's notes about this and that makes complete sense, but if you would like a separate menu definitions file for each Vault, and are interested in an off-the-wall idea, here's one for you.
  • Store the MenuDefinitions.xml in the same place in each Vault, say $/Configuration/VDS/MenuDefinitions.xml
  • Create a small add-in that captures the OnLogOn event
  • In the event handler you can
    • Check for C:\ProgramData\Autodesk\Vault 2025\Extensions\DataStandard\Vault.Custom\MenuDefinitions.xml
    • Calculate the checksum for that file - https://adndevblog.typepad.com/manufacturing/2012/07/how-to-calculate-checksum.html
    • Compare that with the checksum of the current version of $/Configuration/VDS/MenuDefinitions.xml ( the CkSum property of the file)
    • If it matches, VDS is configured for that Vault
    • If it doesn't match
      • Download $/Configuration/VDS/MenuDefinitions.xml
      • Copy it to C:\ProgramData\Autodesk\Vault 2025\Extensions\DataStandard\Vault.Custom
      • Get the details of the running instance of Vault Pro
      • Start a new instance of Vault Pro, which will then use the correct MenuDefinitions.xml
      • Kill the running instance
This code shows how to kill Vault Pro from an add-in
public void OnLogOn(IApplication application)
    System.Diagnostics.Process nProcess = System.Diagnostics.Process.GetCurrentProcess();
    int nProcessID = nProcess.Id;
    string sProcessName = System.Diagnostics.Process.GetCurrentProcess().ProcessName;
    DialogResult res = MessageBox.Show("Hello World Extension loaded by process " + sProcessName + " with ID " + nProcessID.ToString() + " Close (Y/N)", "Close", MessageBoxButtons.YesNo);
    if (res == DialogResult.Yes)
        nProcess.Kill();
Hope that's of interest.
Nick
