VDS-MFG-20025.1.0.1 - Inventor
Paula.N
Paula.N
Updated from Autodesk Data Standard 2025.1 to MFG-Data Standard 2025.1.0.1 Got this error:VDS-NewError.jpg
The specified folderName is a legitimate folder in Vault.
Is there a place where this is defined?
many thanks
It seems to be a problem with the Vault links
Markus.Koechl
What is the update level of Vault? If you run Vault 2025 Update 2, download the latest VDS-MFG-Sample configuration 2025.2.0.0. The shortcuts are handled differently now in the latest configuration. If your environment still runs Update 1, more information about the blurred (screenshot) key/value pair and the related Vault folder(s) is required to reproduce.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Paula.N
Hi Markus,
we have updated from 2025.0 to 2025.1 and replaced the Autodesk Data Standard with VDS-MFG 2025.1.0.1
Markus.Koechl
Hi Paula, I checked the change history of VDS-MFG 2025.1.0.1. A minor update on the Shortcut template has affected the creation of new shortcuts. But - we know Inventor-Vault Update 1 has an issue sharing the user-defined shortcuts with the Vault Client (Distributed Shortcuts are fine). To resolve this limitation, you must update to Vault 2025.2 level.
Anyway - you should be able to run VDS-I on update level 1, but don't create shortcuts while both clients are open: Vault Client and Inventor-Vault. The inventor will reset all shortcuts (user-defined) to the initial start state.
Regarding your error message, I need more details, particularly the reproduction steps.
Markus Koechl
Paula.N
That seems to be a lot of work or trouble.
I believe the optimal approach is to upgrade to Inventor 20252 and Vault 2025.2, and utilize VDS-2025.2.
Many thanks for the information.
