VDS-Last saved Folder
AIT-Hermann
AIT-Hermann
I use VDS-MFG-Sample2025.3
When I save a model and make a drawing, the save path of the drawing is often not the same, but should.
And since I can't set this in the VDS dialogue, my question is:
Can this be configured somewhere?
Markus.Koechl
Update 3 resolved the regression of Update 2 and presets the model's path as a drawing location. The changes in the script are highlighted in green; you can change your configuration in this area.
I hope this answers your question.
- drawings that re-use the model's number as a file name preset the path to the model's location rather than the last used folder.
- if you prefer to re-use the last used folder in any case, you can remove the suggestion and strictly call 'SetFolderByLastSelectedPath'
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
