VDS create folder tree from template 2021
RamOnWe
RamOnWe
Hello all,
I am still very new in customizing and just can't find the solution to my problem.
Currently I am trying to create a folder structure according to a template via VDS. Have already read some posts but it does not work yet.
My CreateFolder.ps1
$folderId=$vaultContext.CurrentSelectionSet[0].Id
$vaultContext.ForceRefresh = $true
$dialog = $dsCommands.GetCreateFolderDialog($folderId)
#override the default dialog file assigned
$xamlFile = New-Object CreateObject.WPF.XamlFile "ADSK.QS.Folder.xaml", "C:\ProgramData\Autodesk\Vault 2021\Extensions\DataStandard\Vault.Custom\Configuration\ADSK.QS.Folder.xaml"
$dialog.XamlFile = $xamlFile
$result = $dialog.Execute()
$dsDiag.Trace($result)
if($result)
	#new folder can be found in $dialog.CurrentFolder
	$folder = $vault.DocumentService.GetFolderById($folderId)
	$path=$folder.FullName+"/"+$dialog.CurrentFolder.Name
	#recursively add subfolders to new folders that are not base category folders
	$UIString = mGetUIStrings
	$NewFolder = $vault.DocumentService.GetFolderByPath($path)
	if($NewFolder.Cat.Catname -eq $UIString["CAT6"])
		#the new folder is the targetfolder to create subfolders, the source folder is the template to be used
		$TempFolderName = "$/00_Administration/00_ProjektStruktur/Kunde/Standort" + $NewFolder.Cat.Catname
		$tempFolder = $vault.DocumentService.GetFolderByPath($TempFolderName)
		If($tempFolder){ mRecursivelyCreateFolders -targetFolder $NewFolder -sourceFolder $tempFolder}
	$selectionId = [Autodesk.Connectivity.Explorer.Extensibility.SelectionTypeId]::Folder
	$location = New-Object Autodesk.Connectivity.Explorer.Extensibility.LocationContext $selectionId, $path
	$vaultContext.GoToLocation = $location
Library.ps1
function mRecursivelyCreateFolders($sourceFolder, $targetFolder)
	If(-not $Global:FldPropDefs){
		$Global:FldPropDefs = $vault.PropertyService.GetPropertyDefinitionsByEntityClassId("FLDR")
		$Global:FldPropDefIds = @()
		$Global:FldPropDefs| ForEach-Object {
			If($_.IsSys -eq $false)
				$Global:FldPropDefIds += $_.Id
    $sourceSubFolders = $vault.DocumentService.GetFoldersByParentId($sourceFolder.Id,$false)
		$mFldIdsArray = @() #collect the level's folder(s) Id(s)
		$propInstParamArrayArray = @()
		foreach ($folder in $sourceSubFolders) {
			$mSourceFldrProps = $vault.PropertyService.GetProperties("FLDR", @($folder.id) , $Global:FldPropDefIds)
			$mSourceUdpInstArray = @()
			$mSourceUdpInstArray += 	$mSourceFldrProps | Where-Object { $Global:FldPropDefIds -contains $_.PropDefId}
			$newTargetSubFolder = $vault.DocumentServiceExtensions.AddFolderWithCategory($folder.Name, $targetFolder.Id, $folder.IsLibrary, $folder.Cat.CatId)
			$mFldIdsArray  += $newTargetSubFolder.Id
			$propInstParamArray = New-Object Autodesk.Connectivity.WebServices.PropInstParamArray #collect the folder's property instance arrays
			Foreach($Inst in $mSourceUdpInstArray)
				$propInstParam = New-Object Autodesk.Connectivity.WebServices.PropInstParam
				$propInstParam.PropDefId	= $Inst.PropDefId
				$propInstParam.Val = $Inst.Val
				$propInstParamArray.Items += $propInstParam
			$propInstParamArrayArray += $propInstParamArray
			mrecursivelyCreateFolders -targetFolder $newTargetSubFolder -sourceFolder $folder
			#returning to the initial level we can update the level folder's properties
		Try{
				$vault.DocumentServiceExtensions.UpdateFolderProperties($mFldIdsArray, $propInstParamArrayArray)
			catch {}
} #end function mRecursivelyCreateFolders
In dataStandardVaultlob.txt I get an error.
2021-05-06 22:06:41,655 [1] ERROR CreateObject.WPF.DSNumSchemeCtrl - DSNumSchemeCtrl_ValueChanged:System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei Common.NumberingScheme.NumSchmService.GetNumSchmFields(NumSchm numSchm)
bei CreateObject.WPF.DSNumSchemeCtrl.DSNumSchemeCtrl_ValueChanged(Object sender, RoutedPropertyChangedEventArgs`1 e)
2021-05-06 22:06:46,497 [1] ERROR CreateObject.WPF.DSNumSchemeCtrl - Invalid numschm value. Only object of Type NumSchm are accepted as value.
Can someone give me a hint what i am doing wrong?
Markus.Koechl
Does the basic folder creation for a project category work? Does your Vault have a numbering scheme of the same name as the project category?
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
RamOnWe
Hi Markus,
thanks for your reply and sorry for the late response.
I was able to solve my problem myself in the meantime. I have searched for the category on the wrong level.
CreateFolder.ps1
if($NewFolder.Cat.Catname -eq $UIString["CAT6"])#Category Project
		$TempFolderName = "$/00_Administration/05_FolderStructures/Customer/Location/" + $NewFolder.Cat.Catname
		If($tempFolder){mRecursivelyCreateFolders -targetFolder $NewFolder -sourceFolder $tempFolder}
"CAT6" is category named "Project" and below the ".../Location/" folder the temp folder category has to be "Project".
My mistake was that former I pointed to ".../Location/Project/".
So now everything is working fine.
