Vault Transmittal Report how to display Custom Object UDPs
dmorse
dmorse
I've created a custom object titled Transmittal, and I've got several UDPs I've created that I have assigned to the Transmittal custom object.  Then, I have a customized Transmittal that has the properties I created, as data in the report.  I would like to have the customized report populated with the UDP data as it is filled out in the properties in vault.  I can't seem to get them to populate, while properties that are assigned and mapped to file properties do populate.  What am I missing on how to get these to populate?
 Thanks!
___________________________________
Dave Morse, Sr. Technical Specialist
APPLIED SOFTWARE | Harnessing the Power to Go Further | 800.899.2784 | LiveLab Learning
ihayesjr
@dmorse
That row in the report is based on the information in the file, not a Custom Object linked to the file.
Your row must be about the custom object.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
christian_gessner
@dmorse & @ihayesjr
Here is an example of a custom job that generates RDLC reports: https://github.com/coolOrangeLabs/sample-workflows/tree/main/Automation/Create%20Time-Triggered%20Re...
It's based on COOLORANGE powerJobs and customizable via PowerShell scripting, which means you could extend the generation of the report data to also read UDPs from linked Custom Objects. The function GetReportDataSet and your RDLC file would need to be extended.
Dave, drop me an email in case you need assistance on how to extend the job to read linked Custom Object properties.
Christian
coolorange logo
Christian Gessner – Head of Research & Innovation
https://www.coolorange.com
https://www.linkedin.com/in/christian-gessner
dmorse
Thank you, Christian.  I will look over the content you shared and get with you if needed.  Really appreciate it.
