Vault Jobhandler is not able to create Autocad Instance since Autocad update 2026.1
gbadziura
gbadziura
Hello everyone
I have a problem where my job handler, which starts AutoCAD, cannot create a new instance of AutoCAD after updating from AutoCAD 2026.0.1 to 2026.1.
I explicitly created a new job handler that only tests the AutoCAD startup to avoid any interference with other code. Unfortunately, I always get the same result.
 public void StartAcad()
     AcadApplication _Acadreturn = null;
     string AcadProgID = "AutoCAD.Application";
     try
         try
             _Acadreturn = (AcadApplication)RunninObjectTable.GetActiveObject(AcadProgID);
         catch (Exception)
             Type AC = Type.GetTypeFromProgID(AcadProgID);
             if (AC != null)
                 _Acadreturn = (AcadApplication)Activator.CreateInstance(AC, true);
             else
                 //Console.WriteLine("Wrong AutoCAD ProgID : " + AcadProgID);
     catch (System.Exception ex)
         //Console.WriteLine($"{ex.Message} : {ex.StackTrace}");
         //The ErrorMessage
         //Retrieving the COM class factory for component with CLSID [607BBE5B-A4EE-47EB-88C9-75FE5F12EAC7] failed due to the following error:
         //80080005 Starten des Servers fehlgeschlagen (0x80080005 (CO_E_SERVER_EXEC_FAILURE)). :
         //at System.RuntimeTypeHandle.AllocateComObject(Void* pClassFactory)
         throw;
when this line of code is called...
...this AutoCAD error message appears.
The exception contains this message
Retrieving the COM class factory for component with CLSID [607BBE5B-A4EE-47EB-88C9-75FE5F12EAC7] failed due to the following error: 80080005 Starten des Servers fehlgeschlagen (0x80080005 (CO_E_SERVER_EXEC_FAILURE)). : at System.RuntimeTypeHandle.AllocateComObject(Void* pClassFactory)
However, the same code works fine from a console application. So it must be something in the job processor environment.
I have installed all updates for AutoCAD 2026, Vault2026, and all installed Autodesk products.
Does anyone have any ideas?
Best regards
Gerhard
Markus.Koechl
Hi @gbadziura : Vault 2026 Update 1 included an updated SDK; the change reflects newer licensing libraries required for Autodesk applications consuming the same. Your console app might not run into this conflict, whereas a custom job likely does. I suggest installing and referencing the SDK 2026.1.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
gbadziura
Hello @Markus.Koechl
This is not about the Vault 2026.1 update. I have been using it since it was released. The problem only occurs when you apply the 2026.1 update from AutoCAD.
As I said, everything works perfectly with Vault 2026.1 and AutoCAD 2026.0.1. Vault 2026.1 and AutoCAD 2026.1 do not work!
Furthermore, I do not supply Autodesk DLLs. Whatever the client has installed is used.
So I don't understand how licensing could play a role here. The only thing that has changed here is AutoCAD.
Best Regards
Gerhard
Markus.Koechl
Hi @gbadziura, now I got you. Please submit a support ticket.
Thanks.
Markus Koechl
