Vault folder.
Vault folder.
Vault folder.
If I have a Vault file. How can I get the Vault folder for the file? There are no folder in the list (see picture.)
Found it.
Dim oVaultFolder As Autodesk.Connectivity.WebServices.Folder()
oVaultFolder = m_docSvc.GetFoldersByFileMasterId(selectedFile.File.MasterId)
Dim sVaultFolder As String
sVaultFolder = oVaultFolder(0).FullName
Be carefull. You might end up with the wrong folder as you are refering to the masterID of all versions.
I believe docserv.FindFoldersBySearchConditions() is the "secure" route.
Redmond.D
GetFoldersByFileMasterId is the right function to use.  It is perfectly "secure".  If a file is moved, all versions move.  It's not possible for version 1 and version 2 of a file to be in different folders.
I don't think FindFoldersBySearchConditions can be used to locate a Folder from the information in a File object.
Lastly, in Vault 2014, the File object *finally* has a FolderId property.
Doug Redmond
Software Engineer
Autodesk, Inc.
Thanks for the error correction!
