Vault Data Standard - Blank Rows in Combo Box
Darin.Green
Mentor Mentor
Message 1 of 8
Darin.Green
Issue:
Within my combo box, there are a number of blank rows before the row containing information:
The combo box has uses the SelectedItem from the previous Combo Box.
Below is the XML structure of the content. NOTICE: There are a number of Types listed before my Build attributes. Those are actually the blank lines in my Combo Box...
I would like to know how to get rid of the blank rows...
Any help would be appreciated.
Darin
If this information was helpful, please consider using the Accept Solution
Replies (7)
Message 2 of 8
wangdu
It is difficult to say what could be the cause for the blank rows. Maybe you could post a simple sample (xaml + xml etc.) that reproduces this behaviour so that I can give a look.
Anyway, FYI, I have found a nice example on the web that uses XmlDataProvider and XPath queries to filter unwanted data. https://docs.microsoft.com/en-us/dotnet/framework/wpf/data/how-to-bind-to-xml-data-using-an-xmldatap...
Wangdu
coolOrange
www.coolOrange.com
Message 3 of 8
Darin.Green
@wangdu
I was able to remove the blank rows using a DataContext method as follows:
<ComboBox x:Name="Build1" Height="Auto" Grid.Row="6" Grid.Column="1"
  ItemsSource="{Binding XPath=Build}"
  DataContext="{Binding SelectedItem, ElementName=Option1}"
  DisplayMemberPath="@Build"
  SelectedValuePath="@Build"
  SelectedValue="{Binding Prop[Building].Value}"/>
Although it's displaying correctly, the value within the Custom Property is no longer selected when the dialog is opened...
The Property is already set to 1 for Building, but the form is no longer selected that value since making the changes above. @wangdu, Do you know why that may be?
Darin
Message 4 of 8
wangdu
Is it the Mode property that you have to set to TwoWay?
  SelectedValue="{Binding Prop[Building].Value, Mode=TwoWay}"/>
Hope this helps!
Wangdu
coolOrange
www.coolOrange.com
Message 5 of 8
Darin.Green
@wangdu
Changing the Mode to TwoWay didn't help.
Do you know if there's something I can add into the Default.ps1 file to not list the blank rows? I'm open to anything at this point.
Message 6 of 8
wangdu
hi,
  ItemsSource="{Binding XPath=./Build/@Type}"
  SelectedIndex="0"
  SelectedItem="{Binding Prop[Building].Value}"/>
Does this help? I am assuming the 'Type' attribute is what you want in the Prop[Building].Value. Correct the attribute name, if that's not the one.
Wangdu
coolOrange
www.coolOrange.com
Message 7 of 8
Darin.Green
@wangdu
I was able to resolve the issue by incorporating LastChild.ChildNodes
<ComboBox
   x:Name="Build1"
   Height="Auto"
   Grid.Row="7"
   Grid.Column="1"
   ItemsSource="{Binding SelectedItem.LastChild.ChildNodes, ElementName=Option1}"
Message 8 of 8
wangdu
Glad that you have been able to resolve the issue.
You could accept it as solution and could help some others in the future..
Wangdu
coolOrange
