Vault Client SDK 2025 issues
mgrenier1
mgrenier1
I'm trying to get the HelloWorld VB sample from the SDK to run and I'm getting some errors when I execute it in Visual Studio CE 2022.
Erreur	BC30002	Le type 'Autodesk.Connectivity.Extensibility.Framework.ExtensionId' n'est pas défini.	HelloWorldVB	C:\Users\mgrenier\Documents\Vault SDK\VB\HelloWorldVB\HelloWorldVB\HelloWorldCommandExtension.vb	31	Actif
Erreur	BC30002	Le type 'Autodesk.Connectivity.Extensibility.Framework.ApiVersion' n'est pas défini.	HelloWorldVB	C:\Users\mgrenier\Documents\Vault SDK\VB\HelloWorldVB\HelloWorldVB\HelloWorldCommandExtension.vb	34	Actif
The reference does seem to be present in my project
Any ideas what I could be doing wrong here?
mfoster9TD82
You'll need to re-add those references, they are located in this folder
C:\Program Files\Autodesk\Vault Client 2025\Explorer
Markus.Koechl
We recommend that you always copy the samples with the .bin folder. The references have relative paths, so if you copy .\Bin + .\VS22 as a pair, all references are kept.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
