Vault CheckIn events not available during first check-in
Hi! I am trying to implement the Post-Check-In event which works fine. But it works only if the file is already checked in into the Vault. For the new files which are not available in Vault, and checked-in for the first time the events are not fired. Is this a normal behaviour? Is there the way to avoid this behaviour?
Thanks a lot!
psaarloos
Hi Patrick,
You should use the AddFile for this.
Hope it helps!
Pim Saarloos
Product Manager
If my post answers your question, please click the "Accept as Solution" button. Kudos are much appreciated!
