Vault API tool - check if file is in vault.
Jef_E
Jef_E
Hello there,
I'm new to the vault programming and would like to start with making a fairly easy ( correct me if i'm wrong ) tool. This tool will have as purpose: supporting the user in getting all data in the vault.
At my workplace we use Vault Basic since not so long. And some ( mostly the older users ) have difficulties putting the drawings into vault after creating them. If it's in vault they are consistant in checking the files into vault because the dialog says to do so.
So what I would like to do first: Check for all *.dwg files in a certain path if they also exist in vault.
Q: How do you check if a file is in vault based on the path?
Secondly i would like to check for the file status:
Q: How do you check the file status based on the file path?
If someone can help me how to start, or point me to a good tutorial or guide, that would be awesome.
We are currently using vault 2014.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Patrick.Gruber
Hello Jef_E,
I would suggest to you powerVault, it's a set of powerShell commandlets and you can write easly scripts. For instance of checking if a file exists you could script something like this:
$file = Get-VaultFile -File "$/Designs/Pad Lock/Test.dwg"
if($file -eq $null) {
   throw "File Test.dwg does NOT exist."
If you want to check the status of a file you could extend the script like:
$fileStatus = $file._State
Write-Host "Status of Test.dwg is '$fileStatus'"
If you are interested in this free application go here http://coolorange.com/de/apps_vault.php the documentation you can find here:
http://www.coolorange.com/wiki/doku.php?id=powervault
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos!
The author,
Patrick
coolOrange
www.coolOrange.com
Here is some code you can maybe use? rewrite
I use it to check for pdfs when we create documentation where i merge several pdf files into one!
CheckIfFileExistInVault(Pdffilename & ".pdf")
Private Sub CheckIfFileExistInVault(ByVal VaultFileName As String)
Dim win As System.Security.Principal.WindowsIdentity
win = System.Security.Principal.WindowsIdentity.GetCurrent()
Dim UserName = win.Name '.Substring(win.Name.IndexOf("\") + 1)
Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("Name of Vault server", "Name of vault", UserName, "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
Dim connection As VDF.Vault.Currency.Connections.Connection = results.Connection
If Not results.Success Then
'MsgBox("Login error")
Return
If results.Success Then
'Start at the root Folder.
Dim root As VDF.Vault.Currency.Entities.Folder = connection.FolderManager.RootFolder
Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
Try
' Get the FileIteration
oFileIteration = getFileIteration(VaultFileName, connection)
If oFileIteration Is Nothing Then
VaultFileIsExisting = False
VDF.Vault.Library.ConnectionManager.LogOut(connection)
Exit Sub
Else
'MsgBox("File found" &  vaultfilename)
VaultFileIsExisting = True
Exit Sub
Catch ex As Exception
Exit Sub
End Try
End Sub
Public Function getFileIteration(ByVal nameOfFile As String, ByVal connection As VDF.Vault.Currency.Connections.Connection) As VDF.Vault.Currency.Entities.FileIteration
Dim conditions As ACW.SrchCond()
ReDim conditions(0)
Dim lCode As Long = 1
Dim Defs As ACW.PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
Dim Prop As ACW.PropDef = Nothing
For Each def As ACW.PropDef In Defs
If def.DispName = "File Name" Then
Prop = def
Next def
Dim searchCondition As ACW.SrchCond = New ACW.SrchCond()
searchCondition.PropDefId = Prop.Id
searchCondition.PropTyp = ACW.PropertySearchType.SingleProperty
searchCondition.SrchOper = lCode
searchCondition.SrchTxt = nameOfFile
conditions(0) = searchCondition
' search for files
Dim FileList As List(Of Autodesk.Connectivity.WebServices.File) = New List(Of Autodesk.Connectivity.WebServices.File)()
Dim sBookmark As String = String.Empty
Dim Status As ACW.SrchStatus = Nothing
While (Status Is Nothing OrElse FileList.Count < Status.TotalHits)
Dim files As Autodesk.Connectivity.WebServices.File() = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(conditions, Nothing, Nothing, True, True, sBookmark, Status)
If (Not files Is Nothing) Then
FileList.AddRange(files)
End While
For i As Integer = 0 To FileList.Count - 1
If FileList(i).Name = nameOfFile Then
oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, FileList(i))
Next
Return oFileIteration
End Function
Regards Kent boettger
Jef_E
Is there a certain file that I need to reference in Visual Studio to get this to work? For Inventor there is a interop.dll file.
Inventor 2014 SP2
try these
Imports Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.WebServicesTools
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports Autodesk.DataManagement.Client.Framework.Vault.Services
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections
Imports ACW = Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.Explorer.ExtensibilityTools
regards. kent boettger
