Here is some code you can maybe use? rewrite
I use it to check for pdfs when we create documentation where i merge several pdf files into one!
CheckIfFileExistInVault(Pdffilename & ".pdf")
Private Sub CheckIfFileExistInVault(ByVal VaultFileName As String)
Dim win As System.Security.Principal.WindowsIdentity
win = System.Security.Principal.WindowsIdentity.GetCurrent()
Dim UserName = win.Name '.Substring(win.Name.IndexOf("\") + 1)
Dim results As VDF.Vault.Results.LogInResult = VDF.Vault.Library.ConnectionManager.LogIn("Name of Vault server", "Name of vault", UserName, "", VDF.Vault.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
Dim connection As VDF.Vault.Currency.Connections.Connection = results.Connection
If Not results.Success Then
'MsgBox("Login error")
Return
End If
If results.Success Then
'Start at the root Folder.
Dim root As VDF.Vault.Currency.Entities.Folder = connection.FolderManager.RootFolder
Dim oFileIteration As VDF.Vault.Currency.Entities.FileIteration = Nothing
Try
' Get the FileIteration
oFileIteration = getFileIteration(VaultFileName, connection)
If oFileIteration Is Nothing Then
VaultFileIsExisting = False
VDF.Vault.Library.ConnectionManager.LogOut(connection)
Exit Sub
Else
'MsgBox("File found" & vaultfilename)
VaultFileIsExisting = True
Exit Sub
End If
Catch ex As Exception
Exit Sub
End Try
End If
End Sub
Public Function getFileIteration(ByVal nameOfFile As String, ByVal connection As VDF.Vault.Currency.Connections.Connection) As VDF.Vault.Currency.Entities.FileIteration
Dim conditions As ACW.SrchCond()
ReDim conditions(0)
Dim lCode As Long = 1
Dim Defs As ACW.PropDef() = connection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
Dim Prop As ACW.PropDef = Nothing
For Each def As ACW.PropDef In Defs
If def.DispName = "File Name" Then
Prop = def
End If
Next def
Dim searchCondition As ACW.SrchCond = New ACW.SrchCond()
searchCondition.PropDefId = Prop.Id
searchCondition.PropTyp = ACW.PropertySearchType.SingleProperty
searchCondition.SrchOper = lCode
searchCondition.SrchTxt = nameOfFile
conditions(0) = searchCondition
' search for files
Dim FileList As List(Of Autodesk.Connectivity.WebServices.File) = New List(Of Autodesk.Connectivity.WebServices.File)()
Dim sBookmark As String = String.Empty
Dim Status As ACW.SrchStatus = Nothing
While (Status Is Nothing OrElse FileList.Count < Status.TotalHits)
Dim files As Autodesk.Connectivity.WebServices.File() = connection.WebServiceManager.DocumentService.FindFilesBySearchConditions(conditions, Nothing, Nothing, True, True, sBookmark, Status)
If (Not files Is Nothing) Then
FileList.AddRange(files)
End If
End While
For i As Integer = 0 To FileList.Count - 1
If FileList(i).Name = nameOfFile Then
oFileIteration = New VDF.Vault.Currency.Entities.FileIteration(connection, FileList(i))
End If
Next
Return oFileIteration
End Function
Regards Kent boettger
