Vault API Login Problem
Marco.Vasconcelos
Marco.Vasconcelos
Hello, everyone! I am trying to do my first steps with Vault API via PowerShell but now I'm stuck and would very much appreciate your help. When I run the code I receive a error 404: New-Object : Exception calling ".ctor" with "1" argument(s): "The remote server returned an error: (404) Not Found."
I tried many modifications and tested and different machines but I'm now completely lost on what the problem could be.
Following is my current code (Vault 2023):
[System.Reflection.Assembly]::LoadFrom("C:\Program Files\Autodesk\Vault Client 2023\Explorer\Autodesk.Connectivity.WebServices.dll")
$cdnVaultServer="<ServerIP>"
$cdnVaultName="Vault"
$cdnVaultUser="Administrator"
$cdnVaultUserPsw="<Password>"
$cdnVaultReadOnly= $false
$licenseAgent = [Autodesk.Connectivity.WebServices.LicensingAgent]::Client
$mServer = New-Object Autodesk.Connectivity.WebServices.ServerIdentities
$mServer.DataServer = $cdnVaultServer
$mServer.FileServer = $cdnVaultServer
$cdnCredentials = New-Object Autodesk.Connectivity.WebServicesTools.UserPasswordCredentials ($mServer, $cdnVaultName, $cdnVaultUser, $cdnVaultUserPsw, $licenseAgent)
$cdnVault = New-Object Autodesk.Connectivity.WebServicesTools.WebServiceManager($cdnCredentials)
$cdnWebServiceManager.AdminService.GetAllUsers()
Markus.Koechl
You are missing an important step: copy the licensing dll into the PowerShell directory. Find the detail in the note of my code template below.
To get started with Powershell for Vault, I recommend two AU classes:
Autodesk Vault 2020—Programming 101 | Autodesk University and Feel the Power Between Vault and PowerShell | Autodesk University.
The class targeted Vault 2020, but the code below matches 2023.
#region disclaimer
	# PowerShell script sample
	# Author: Markus Koechl
	# Copyright (c) Autodesk 2021
	# THIS SCRIPT/CODE IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER
	# EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
	# OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT.
#endregion
#region ConnectToVault
		# NOTE - click licensing v6 requires to copy AdskLicensingSDK_6.dll to PowerShell execution folder C:\Windows\System32\WindowsPowerShell\v1.0 before Powershell runtime starts
		[System.Reflection.Assembly]::LoadFrom('C:\Program Files\Autodesk\Autodesk Vault 2023 SDK\bin\x64\Autodesk.Connectivity.WebServices.dll')
		$serverID = New-Object Autodesk.Connectivity.WebServices.ServerIdentities
			$serverID.DataServer = "<ServerName or IP>"
			$serverID.FileServer = "<ServerName or IP>"
		$VaultName = "<Name of Vault>"
		$UserName = "<User Name>"
		$password = "<Password>"
		#Select license type by licensing agent enum "Client" (=Named User) "Server" (= (legacy) Multi-User) or "None" (=readonly access) or "Token" (Autodesk ID)
		$cred = New-Object Autodesk.Connectivity.WebServicesTools.UserPasswordCredentials($serverID, $VaultName, $UserName, $password, $licenseAgent)
		$vault = New-Object Autodesk.Connectivity.WebServicesTools.WebServiceManager($cred)
		#region ExecuteInVault
			#query vault, download files, etc....
		#endregion ExecuteInVault
		$vault.Dispose() #don't forget to release the connection, to return the (server) license you also can log out: $cred.SignOut($vault.AuthService, $vault.WinAuthService)
#endregion ConnectToVault
Hope this helps.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
