Vault And Python
Vault And Python
Message 1 of 18
Vault And Python
Hi
   Can i use python to interact with Autodesk vault ?   If yes can you tell me where i can get the information do to it ?
Thank
Replies (17)
Message 2 of 18
ihayesjr
Vault is not supported with Python.
Irvin Hayes Jr
Principal Product Manager
Autodesk, Inc.
Vault - Under the Hood Blog
Message 3 of 18
Hello
 I know your answer was in 2016. What about 2019? Still do not support Python?
Juan
Message 4 of 18
ihayesjr
We have no plans to support Python in current or future releases.
Irvin Hayes Jr
Autodesk, Inc.
Message 5 of 18
Message 6 of 18
Does anybody know whether it's possible to work around the lack of Python support and use Python anyway?
Perhaps by calling the Vault .NET libraries from Python?
I might try this soon as I wasn't able to get anything working with .NET in Visual Studio. Not even the examples.
Message 7 of 18
spascual
Hi gmeinders,
Recently we have developed a connector between Odoo and Autodesk Vault Pro in order to retrieve data from Item Master. Using Web Services this connector has been entirely developed in Python.
https://forums.autodesk.com/t5/vault-customization/odoo-vault-pro-connector/td-p/8751186
I have some videos for the usability.
https://youtu.be/OjCCydzATmw
If need more info, contact me.
Message 8 of 18
For others interested in using Python syntax to access Vault, IronPython can be used for this.
I did some tests and it seems to be working (there are 0 examples online though).
Now what I need is VDF documentation which I can't find anywhere. Can anybody point me in the right direction for documentation that shows the entire VDF API, methods, arguments, what the methods return, objects, etc? All I can find are very limited examples and very general explanations.
Where's the API documentation hidden? I found some info in the XML files that come with the VDF dll's, but there must be something better?
PS: can someone please fix this forum for Firefox? The useless "Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied." error is driving me kind of nuts. Had to switch to Edge to use this website?!
Message 9 of 18
asmeltzer
Message 10 of 18
cavallerin
Hi, it seems links are not more available, could you please post new ones? Thanks
Message 11 of 18
tomas.pascual
Message 12 of 18
tomas.pascual
We already have a python script in Excel that retrieve data from vault based on itemNumber.
Message 13 of 18
cavallerin
I'm sorry, but haven't checked till now this thread.
Well is it possible to share with me how you managed to connect to the Vault?
Thx!
Message 14 of 18
tomas.pascual
Hi Cavallerin,
Sure,
# -*- coding: utf-8 -*-
# License AGPL-3.0 or later (http://www.gnu.org/licenses/agpl).
import xlwings as xw
import zeep
@xw.sub
def main():
    client = zeep.Client(wsdl=url)
    sign_in = client.service.SignIn(userName='######', userPassword='######', knowledgeVault='######')
    token = sign_in.Authorization
    user_id = sign_in.User.Id
    wb = xw.Book.caller()
    numbers = wb.sheets[0].range('C2').expand('down')
    i = 1  # Indice para recorrer columnas, uno menos que el range de numbers
    # Acceso al servicio de Artículos
    settings = zeep.Settings(extra_http_headers={'Authorization': token})
    client_item = zeep.Client(wsdl=url_item, settings=settings)
    # Acceso al servicio de Propiedades
    client_prop = zeep.Client(wsdl=url_prop, settings=settings)
    for rec in numbers:
        i = i + 1
        GetVaultItems = client_item.service.FindItemRevisionsBySearchConditions(
            searchConditions={'SrchCond': {'PropDefId': 31,
                                    'SrchOper': 3,
                                    'PropTyp': 'SingleProperty',
                                    'SrchRule': 'Must',
                                    'SrchTxt': rec.formula,
            bRequestLatestOnly=True,
        if GetVaultItems.searchstatus.TotalHits == 1:
            Title = GetVaultItems.FindItemRevisionsBySearchConditionsResult.Item[0].Title
            Id = GetVaultItems.FindItemRevisionsBySearchConditionsResult.Item[0].Id
            GetVaultItemsCustomProperties = client_prop.service.GetProperties(
                entityClassId='ITEM',
                entityIds={'long': Id},
                propertyDefIds={'long': [37, 141, 165, 171, 172]},
            Units = GetVaultItemsCustomProperties[0].Val
            SapMatGr = GetVaultItemsCustomProperties[1].Val
            SapMatTy = GetVaultItemsCustomProperties[2].Val
            Aprov = GetVaultItemsCustomProperties[3].Val
            AprovEsp = GetVaultItemsCustomProperties[4].Val
        else:
            Title = '####'
            SapMatGr = '####'
            SapMatTy = '####'
            Aprov = '####'
            AprovEsp = '####'
            Units = '####'
        if not wb.sheets[0].range('D' + str(i)).value:
            wb.sheets[0].range('D' + str(i)).value = Title
        if not wb.sheets[0].range('E' + str(i)).value:
            wb.sheets[0].range('E' + str(i)).value = SapMatGr
        if not wb.sheets[0].range('F' + str(i)).value:
            wb.sheets[0].range('F' + str(i)).value = SapMatTy
        if not wb.sheets[0].range('G' + str(i)).value:
            wb.sheets[0].range('G' + str(i)).value = Aprov
        if not wb.sheets[0].range('H' + str(i)).value:
            wb.sheets[0].range('H' + str(i)).value = AprovEsp
        if not wb.sheets[0].range('I' + str(i)).value:
            wb.sheets[0].range('I' + str(i)).value = Units
if __name__ == "__main__":
    xw.books.active.set_mock_caller()
    main()
Message 15 of 18
cavallerin
Hi and thx a lot!
I'm always late on checking replies as I'm deeply involved in CAD-PDM integration process.
Thx again, I'll give it a check.
Regards!
Message 16 of 18
tomas.pascual
Hi Cavallerin,
There is a new vault rest api which can be accesed easylly from https
https://aps.autodesk.com/developer/overview/vault-data-api
Message 17 of 18
cavallerin
import zeep
@xw.sub
def main():
Hi Tomas,
thx a lot! I have been able to retrieve data from Vault.
Message 18 of 18
tomas.pascual
Amazing !!!
