Vault 2025 VDF doesn't work in AutoCAD 2025 plugin
n_Sovljanski
n_Sovljanski
I have very, very strange situation with implementation VDF in AutoCAD 2025 plugin.
1. I use using VDF = Autodesk.DataManagement.Client.Framework;
2. it is used to listen event in Initialize method
public void Initialize()
		VDF.Vault.Library.ConnectionManager.ConnectionEstablished += ConnectionManager_ConnectionEstablished;
3. With line 3 plugin will not be loaded in AutoCAD 2025. If I commented line 3 plugin will be loaded.
4. everything works fine in AutoCAD/Vault2024
5. There is no compilation error, there is no error, or message from AutoCAD during loading
Does anybody face this issue?
n_Sovljanski
It is solve  by Autodesk support team. If you want to use libraries for Vault 2025 then:
1. Find setup.exe in C:\Program Files\Autodesk\Vault Client 2025\SDK
2. Run Setup.exe and wait to finish job.
3. find folder C:\Program Files\Autodesk\Autodesk Vault 2025 SDK\bin\x64\core
4. in That folder you can find all libraries developed in NET8
