Using a dll inside an Extension
Hello
If I try to use a dll inside an extension I get an error at vault startup.
This Dll comes fron autodesk.I get also source code and recompile it for vs2010 and .NET 4.
Autodesk.Connectivity.Extensibility.Framework Error: 1 : System.IO.FileLoadException: Impossibile caricare il file o l'assembly 'PrintUtil2, Version=1.0.4799.16214, Culture=neutral, PublicKeyToken=null' o una delle relative dipendenze. Tentativo di caricare un eseguibile non verificabile con correzioni (IAT con più di 2 sezioni o una sezione TLS). (Eccezione da HRESULT: 0x80131019)
Nome file: 'PrintUtil2, Version=1.0.4799.16214, Culture=neutral, PublicKeyToken=null' ---> System.IO.FileLoadException: Tentativo di caricare un eseguibile non verificabile con correzioni (IAT con più di 2 sezioni o una sezione TLS). (Eccezione da HRESULT: 0x80131019)
   in System.Reflection.RuntimeAssembly.nLoadImage(Byte[] rawAssembly, Byte[] rawSymbolStore, Evidence evidence, StackCrawlMark& stackMark, Boolean fIntrospection, SecurityContextSource securityContextSource)
   in System.AppDomain.Load(Byte[] rawAssembly)
   in Autodesk.Connectivity.Extensibility.Framework.AssemblyChecker.FindAssembly(AssemblyName reference)
   in Autodesk.Connectivity.Extensibility.Framework.AssemblyChecker.CheckAssemblyRecursive(Assembly assembly)
   in Autodesk.Connectivity.Extensibility.Framework.AssemblyChecker.CheckAssembly(Assembly assembly)
   in Autodesk.Connectivity.Extensibility.Framework.ExtensionLoader.LoadExtension(Extension ext, ExtensionTypeEnum extType)
   in Autodesk.Connectivity.Extensibility.Framework.ExtensionLoader.LoadExtensions(ExtensionTypeEnum extensionType)
Alessandro
Redmond.D
A Google search came up with this:
http://stackoverflow.com/questions/5005409/exception-with-resolving-assemblies-attempt-to-load-an-un...
You can either update PrintUtil2 to a pure .Net DLL or you manage the assembly loading yourself in your code instead of having a project reference.
Doug Redmond
Software Engineer
Autodesk, Inc.
