- Mute
- Permalink
- Report
I have a file in Vault, status readonly.
Checking out the file via API "AcquireFiles" (checkout in settings) method, the file is now checked out and has status editable (not readonly).
I do undo check out with method:
connection.FileManager.UndoCheckoutFile(file);
3 issues regarding Undo check out:
1. If I edit the checked out file and save it and then do a undo checkout I want the workflow to prompt that I am about to loose changes, how do I do that?
2. How do I set "Replace working copies" programmatially?
3. When I have performed the undo check out action, I now expect my file to have been replaced with the latest from Vault and also status of file is readonly. None of this occurs.
Appreciate your help
