The type initializer for 'QuickstartiLogicLibrary.QuickstartiLogicLib' threw an exception
vas_ampelas
Message 1 of 8
vas_ampelas
We have an intermittent issue with our iLogic that uses QuickstartiLogicLibrary to check if file is Checked-out or not... The error message above is thrown to only a small number of PCs, for the majority of PC it is working as expected.
The problem is that we need this to work for every user, as it is used in an event trigger rule that is in all our CAD Model Templates.
(Please find attached iLogic rule and TXT that show the full exception.)
The error message suggest that some object is not set...
I tried come changes to the line 37 in the source code as per below, but no joy...
Some help would be greatly appreciated.
Best Regards,
Vas Ampelas
Replies (7)
Message 2 of 8
Markus.Koechl
Hi @vas_ampelas , would you mind attaching the code, please? Did you check the update level of the clients working vs. clients failing?
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Message 3 of 8
jclements7LNR5
Did you find a solution for this issue?  I am seeing the same thing.
Message 4 of 8
Markus.Koechl
The error likely is caused by missing DLLs on the machines. Note - Inventor 2024 implemented iLogic-Vault as a default, and there is no risk of missing the Quickstart library or the additional required ones from the SDK, depending on what you use.
Markus Koechl
Message 5 of 8
jclements7LNR5
@Markus.Koechl We are using Inventor 2025 and Vault Basic 2025.  The default quickstart library will not run on basic.  We are also all pulling the QuickstartiLogicLibrary.dll from a shared/common location (same as the shared ilogic routines)  I've checked vault and inventor versions on working and non-working machines and they are all the most recent.
Message 6 of 8
Markus.Koechl
@jclements7LNR5. OK, I got your point. So, you had to compile your 2025 version of the QuickstartiLogicLibrary; did you also migrate the code to .NET8? This is what Inventor iLogic 2025 requires.
Markus Koechl
Message 7 of 8
jclements7LNR5
I don't have the expertise to modify a .dll file to .NET8.  Why would it need migrated if it is working on some computers already?
Message 8 of 8
Markus.Koechl
The error "Type initializer threw an exception" is difficult to investigate without the individual environment. Computers that don't throw this exception may have the legacy initializer available. To make it robust, a recompilation with sources that match the target release of Inventor is the best option. At this point, I need to remember to read the QuickstartiLogicLibrary's legal disclaimer: to use this application in production environments requires an individual compilation of the source code anyway. The released binaries are for evaluation only.
Markus Koechl
