Skip the VDS Dialog and show the default Inventor Dialog
MUM_dloew
MUM_dloew
i search for a way to skip the VDS dialog and show the default Inventor dialog.
With $dsWindow.CancelWindowCommand.Execute($this) i can abort the dialog, but nothing elde happens.
have anyone an idea?
Daniel Loew
Application Engineer
Inventor | AutoCAD / M | Vault | Fusion 360
Kudos are greatly appreciated. Everyone likes a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Markus.Koechl
Hi Daniel, could you provide more details about the context and workflow? There are two default options to suppress VDS dialogs showing up: SkipVdsForProperty and the AddIn Disable/Enable configuration. Without understanding the intent, I can hardly suggest a solution path.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
MUM_dloew
hi Markus,
The Customer starts a new 3d Document. when he click save he will have the ability to use the Inventor default save dialog. Not all files must be saved with VDS dialog.
When i click on abort in the VDS dialog the process end.
I can't set it with the SkipPropertie in the InventorConfig. Then i must create 2 Templates. One for Save with VDS, one for Save without.
Daniel Loew
Markus.Koechl
Hi Daniel, in this case, users can use the File -> Save Copy As command. For new files, it does not copy, and this command is intentionally excluded from VDS events. So, this is the "backdoor" that the user can take if they decide to skip. The only customization I see is bringing this command from the nested File -> Save As -> Save Copy As to the main ribbon for frequent use; you could do this quickly as an iLogic command.
Markus Koechl
