Setup iLogic in Vault 2022
jonathan.heinrich
Message 1 of 8
jonathan.heinrich
I would like to setup iLogic in Vault 2022.
I have placed the Autodesk.VltInvSrv.iLogicSampleJob to %ProgramData%\Autodesk\Vault 2022\Extensions
But I don't find iLogic icon in Vault Explorer.
What is the right Way ?
Replies (7)
Message 2 of 8
jonathan.heinrich
Can someone help me ?
Message 3 of 8
dave_taylor
Are you looking to implement the iLogic Vault Extension? Found here: https://github.com/koechlm/Vault-Job-Processor---iLogic-Extension
You might be able to get more details from the readme there...
Dave Taylor
MCAD Solutions Engineer
Hagerman & Co.
Autodesk Certified Instructor - Platinum
*Likes to this post are appreciated if the information I have shared is helpful to you and/or others...
**Did this resolve your issue? Please accept it "As a Solution" so others may benefit from it.
Message 4 of 8
jonathan.heinrich
Yes. iLogic add-in is running in Inventor.
I took the e-learning of Markus Koechl from Autodesk University on iLogic and Vault. I had difficulty understanding the topic. In the Job Processing & iLogic chapter, it was possible to access iLogic Job administration in Vault 2020.
2021-11-18 16_11_58-iLogic and Vault—Vault and iLogic _ Autodesk University.pngLink : iLogic-and-Vault-Vault-and-iLogic-2020
 I would like to setup the same fonction in Vault 2022. It's possible ? What is the right way ?
Message 5 of 8
Markus.Koechl
The AU class is based on a custom Job extension. There is an improved version for Vault 2022 available: https://github.com/koechlm/Vault-Job-Processor---iLogic-Extension/releases/tag/2022.0.2. Download the two *setup* files according to the instruction written in the release note. I hope this helps.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Message 6 of 8
matthias.duve257HN
Hi everyone,
I spend quite some time, figuring out how to get a sample job with ilogic running on Vault 2020.3.
We will not update in the next month, and I want to try and work with some simple ilogic rules for drawings. According to the release notes, such a job should be possible. But I can´t seem to find a "readme" that does not start with: only for Vault 2021 and higher.
@Markus.Koechl  If you could give me a hint on where to start, that would be very appreciated! The history on your github did not help me unfortunately.
Thanks a lot!
Message 7 of 8
Markus.Koechl
I think you figured out that you need to have a custom job environment enabling iLogic-Job-Rules, like the sample that I shared via GitHub. And yes, there is no version for 2020.3. The 2020 codebase has been the first draft (you can download a pre-release here), but the complete implementation that AU classes refer to starts with the 2021 version. I am sorry, there are only two options: if you are familiar with Vault Job Processor API, start with the latest 2022 code and back-port to 2020.3 SDK. Otherwise, I fear you need to update your Vault environment first. Upcoming enhancements will go into the latest and future versions only.
Markus Koechl
Message 8 of 8
matthias.duve257HN
Hi @Markus.Koechl Markus,
thank you for the swift response!! As I´m not too familiar with the Job Processor API, even though we have a few custom jobs, I will seek for more external help in this case. I just didn´t want to miss something that might be already on your github! If something shows up that might help other people, I will continue to answer here.
Thanks again!
Matthias
