Revision Control
Revision Control
Revision Control
Is it possible to use revision Control without using Lifecycles?
If so, could someone please give me a brief explanation to how this should be done?
Markus.Koechl
Yes, you can do this applying the "Revise.." command. Watch attached video; don't worry that it starts with an item revision - just follow how the item's linked files, that don't have any own document lifecycle get revised.
Hope this clarifies the options.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
OK. So a JobProcessor is not nescessary in order to use the revision Control, but it would autmate the tasks. This Works for both items and parts.
