- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi community,
I have used SetBomByFileId to re-write the FileBom.
The new FileBom is the same like the old one but I have removed just 1 component from the CompArray.
The function "SetBomByFileId" throws the error code "1145", but I can nowhere locate the appropriate error message for this code. Where can I find it?
Real Problem
GetBOMByFileId returns Components with XRefIds which do not exist in Vault anymore.
After running the Autodesk Job autodesk.vault.extractbom.inventor on the affected Assembly doesn't write a new FileBom like mentioned in this blog post
The API documentation for SetBomByFileId (which the job should use) says "File cannot have a BOM already associated with it."
Does this mean the job fixes the FileBom only in case there is NO bom at all?
Is there a better way in my case where only some XRefIds are wrong without making a check-in with Inventor?
Had somebody else a similar case? Any help is very appreciated thanks!
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos! 😉
The author,
Patrick
coolOrange
www.coolOrange.com
The author,
Patrick
coolOrange
www.coolOrange.com
