Populating Item UDPs
Message 1 of 9
I am adding Items to Vault 2013 Professonal through the API.
I now have to populate some UDPs that we have defined for Items.
I don't see the Item UDPs for the Item object, so I figure that something else is needed to access them, but I can't find examples in the Help File or here.
Here is where I am at:
// Get our Item Numbering Schema ("Mapped") ID.
long itemNumberingSchemeID = GetItemNumberingSchemeID("Mapped");
// Create a new Item with that Category ID.
newItem = m_ItemSvc.AddItemRevision(GetCatID("Mechanical Detail"));
// Create an array with the desired item number.
string[] newItemNum = newstring[] { itemNumber };
// Create an array of StringArrays with 1 element.
StringArray[] fieldInputs = new StringArray[1];
// Create a single StringArray.
StringArray tempArr = newStringArray();
tempArr.Items = newItemNum;
fieldInputs[0] = tempArr;
// Change Item Number.
ItemNum[] newNums = m_ItemSvc.AddItemNumbers(newlong[] { newItem.MasterId }, newlong[] { itemNumberingSchemeID }, fieldInputs);
// Set Item values.
newItem.ItemNum = itemNumber;
newItem.Detail = GetExcelData("Description");
newItem.Title = "";
// Set Item UDP values.
newItem.BasicMaterial =
newItem.Size =
newItem.Vendor =
Replies (8)
Message 2 of 9
Redmond.D
UpdateItemProperties is the function you want.  However, there are some things you need to know about working with items.
Editing an item usually follows the pattern of:
  1. Put the item in an editable state, which is essentially "checking out the item"
  2. Make changes, such as setting UDP values.
  3. Commit the changes, which is like a "check-in"
For more information, see the "Editing Items" knowledge base article in the SDK documentation.
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 3 of 9
Ok, now I have:
// Create a new Item with that Category ID (Use "Mechanical Detail" for everything for now).
// Set Item values
newItem.Title = "";
string excelUnits = GetExcelData("Base Unit of Measure");
if (excelUnits != "")
   newItem.Units = UnitsMappingDictionary[excelUnits];
else
   newItem.Units = "";
List<string> UDPList = new List<string>();
UDPList.Add("Base Unit of Measure");
UDPList.Add("Basic Material");
UDPList.Add("Part Number");
UDPList.Add("Vendor");
UDPList.Add("Size/Dimension");
//UDPList.Add("Dimension");
int UDPListLength = UDPList.Count();
long[] propDefIdArray = new long[UDPListLength];
string[] propValueArray = new string[UDPListLength];
// get the map between the property name and all Vault objects.
Dictionary<string, PropDef> propDefMap = GetPropDefMap(mgr);
// Get all property values for the Item.
PropInst[] itemProperties = propSvc.GetPropertiesByEntityIds("ITEM", newlong[] { newItem.Id });
string excelCellData = "";
intindex = 0;
// Put UDP values and propDefIds into arrays.
foreach (string item in UDPList)
   excelCellData = GetExcelData(item);
   // Get the property definition from the property name.
   PropDef propDef;
   if (!propDefMap.TryGetValue(item, out propDef) || excelCellData == null)
      continue; // tag value doesn't match any Vault properties, or cell was empty.
   try
      // Add to the list of UDPs and values to set.
      propDefIdArray[index] = propDef.Id;
      propValueArray[index] = excelCellData;
      index++;
   catch (Exception ex)
      MessageBox.Show("Error with property " + item + ":\n"+ ex.Message);
if(index > 0)
   // We have the arrays all set; now do the actual save.
   m_ItemSvc.UpdateItemProperties( new long[] { newItem.RevId }, propDefIdArray, propValueArray );
   // Commit Changes
   m_ItemSvc.UpdateAndCommitItems(new Item[] { newItem });
All seems good except that I get a SOAP error on the last command.  Is that command (UpdateAndCommitItems) necessary?
Message 4 of 9
Redmond.D
Yes, you need to call UpdateAndCommitItems.
When the function fails, what is the error code?
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 5 of 9
Error code 1387.
Message 6 of 9
I see that the resriction code is 2037, ItemNotEditable.  I thought that when a new Item was created, it was in an Editable state, but I guess not.
Message 7 of 9
Redmond.D
I checked some other ADN cases.  It turns out that UpdateItemProperties does a commit of the item.  So I was wrong earlier; you don't need to call UpdateAndCommitItems.
The UpdateItemProperties should mention the commit operation, but it doesn't.  A defect has already been logged.
Doug Redmond
Software Engineer
Autodesk, Inc.
Message 8 of 9
Super.  Thanks for the help Doug.
Message 9 of 9
Here is the final version:
// Get our Item Numbering Schema ID.
// Create the parameter for creating a new Item Number.
string[] newItemNum = new string[] { itemNumber };
// Create a new ItemNum object; we have to tell Vault to expect the new number.
ItemNum newNum = m_ItemSvc.AddItemNumber(newItem.MasterId, itemNumberingSchemeID, newItemNum);
// Set Item values
newItem.ItemNum = newNum.ItemNum1; // Vault knows about the new number now.
newItem.Title = itemNumber;
// Commit the item, which finalizes the object.
// Read the Item back in to update the UDPs.
savedItem = m_ItemSvc.GetLatestItemByItemNumber(itemNumber);
editableItem = m_ItemSvc.EditItem(savedItem.RevId);
// Get the User Defined Properties.
List<string> UDPList = FillUDPList();
int index = 0;
   PropDef propDef;
   if (!propDefMap.TryGetValue(item, out propDef) || String.IsNullOrEmpty(excelCellData))
   try
      index++;
   catch (Exceptionex)
// Redimension the arrays; it will exception if the arrays are not full.
Array.Resize(refpropDefIdArray, index);
Array.Resize(refpropValueArray, index);
if(index > 0)
   m_ItemSvc.UpdateItemProperties(new long[] { editableItem.RevId }, propDefIdArray, propValueArray);
