Numbering per folder
Jens.Bruhn
Message 1 of 10
Jens.Bruhn
Hello all,
I have a special request for file numbering in vault...
We have vault folder names like '100 - Drehteile', '200 - Brennteile' and so on.
In each folder the filenames have the same prefix as the folder name, for example <100-10025.ipt> or <200-10650.ipt>.
I'd like to generate the highest number per folder when a new file is created in Inventor.
I could define an numbering scheme for each folder, but I think with more then 20 folders this is not very smart.
Maybe someone has a better idea with DataStandard?
Can I generate this special number, when the user choose the folder name in the Inventor DataStandard dialog?
Thanks all,
Jens
Replies (9)
Message 2 of 10
COOLORANGE
Hi Jens,
I believe it is possible. In Default.ps1 there is function called OnPostCloseDialog. In this function, you have the chance to rename the file like this: $Prop["_FileName"].Value = "New File name.ipt".
To collect the prefix from the folder, use the $Prop["Folder"].Value.
Finally it could be something like this:
$Prop["_FileName"].Value = $Prop["Folder"].Value + $Prop["_FileName"].Value
Note: I haven't tested it. But I hope it helps you get in the right direction!
Wangdu
coolOrange
www.coolOrange.com
Message 3 of 10
Jens.Bruhn
Hi Wangdu,
thanks for your reply.
With your snippet I can get the prefix from the folder but not the highest file number in this folder.
I solved the problem now with individual numbering schemes because there where too much existing files with individual numbers in different folders.
Thanks again for your note.
Jens
Message 4 of 10
Markus.Koechl
Hi Jens,
you can achieve this easily by the use of a numbering scheme with prompted text, e.g. ?-#####.
With that you will get individual numbering sequences for each folder.
The prompted text (?) = folder number.
There are two approaches to solve this:
1) follow the Vault help example (end of article) and replace the argument "Title" by your number: http://help.autodesk.com/view/VAULT/2016/DEU/?guid=GUID-40E6D520-2E85-46F2-AFD1-89EEBBD06936
regards,
Markus
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
Message 5 of 10
Jens.Bruhn
Hi Markus,
good idea, thanks for this.
I wanted to get the highest number per folder and not over all. So I created an individual numbering scheme per folder.
Thanks again and best regards,
Jens
Message 6 of 10
Markus.Koechl
Hi, I am wondering that why you need more than one scheme. The prompted input causes the sequence to restart automatically for each individual number.
?-##### should result in
1) 100-00000, 100-00001...
2) 200-00000, 200-00001...
Eventually still a hint to optimize.
Markus
Markus Koechl
Message 7 of 10
Jens.Bruhn
Hi Markus,
I tested it with a scheme like you suggested - you are right!
I wasn't aware that the prompted input causes a restart of the sequence.
Thanks a lot and best regards,
Jens
Message 8 of 10
Hi Markus
I am sorry i know this has already been solved.
Is there away to do this through vault when creating a new file in a new folder, which will reset the numbering scheme using data standard to create the new file in vault.
Message 9 of 10
Markus.Koechl
I am sorry, but I don't see what you are looking for differently to the previous question and solution. Can you share a step by step workflow description?
Markus Koechl
Message 10 of 10
Hi Markus
Sorry i manage to sort it out late this afternoon.
I thought the option only worked in the data standard inventor add in, but i see it also works the the vault data standard add in.
sorry for wasting your time.
Thanks.
