Looking for SDK DLLs
shallN6L5D
shallN6L5D
Good morning,
We have a web app that connects to Vault, our ERP system and Forge Viewer to display drawings and models for non-CAD users (yes I know the Vault thin client exists, but that requires a login...)
I need to make some changes to it, which requires recompiling. Now that we are on Vautlt 2024, I referenced the new set of DLLs in the SDK but some seem to be missing according to the messages displayed in Visual Studio. I confirmed that these aren't in C:\Program Files\Autodesk\Autodesk Vault 2024 SDK\bin\x64\
AdskLicensingSDK_5.dll
Autodesk.Connectivity.AdSSOWrapper.dll
Autodesk.Connectivity.WebServices.dll (though I have the ...WCF.dll)
Autodesk.DataManagement.Client.Framework.Vault.Forms.dll
There may be more; this was just what I spotted comparing the previous build to what's in the SDK.
Where could I find versions of these DLLs that are compatible with Vault 2024?
cheers
Simon
Nick_Hall
Hi Simon
For 2024, you will need the following files for licensing
AdSkIdentitySDK.config
AdSkIdentitySDK.dll
AdskLicensingSDK_7.dll
The best way to get hold of these files is to install the Vault SDK and look in the C:\Program Files\Autodesk\Autodesk Vault 2024 SDK\bin\x64
Hope this helps
Nick
shallN6L5D
Hi @Nick_Hall ,
Thanks for confirming. Yes I installed the 2024 Vault SDK and have those three to use as references.
Visual Studio is showing errors due to not being able to load "Autodesk.Connectivity.AdSSOWrapper.dll" which I have since been told has been deprecated.
Maybe it's outside the scope of this forum; if this reference is no longer needed, how do I remove it from the Visual Studio solution?
cheers
Simon
Nick_Hall
Hi Simon
It's usually a case of finding the reference in the Solution Explorer tree, and using right-click -> Remove
Where you find it depends on the version of VS you are using. In 2022, for example, it will probably be in a subfolder of "Dependencies"
Hope that helps
Nick
shallN6L5D
@Nick_Hall That seems to have done it, after some more fiddling with Visual Studio.I did eventually get it to build without errors.
I haven't been able to test it yet as I need to set up an environment with .net 4.8.1...
