List of Checked out files
GrahamB8
GrahamB8
Hi all,
Ive just started looking at doing some basic API work and wanted to make a form which will return a list of checked out files including the users that have them checked out. Sure I can do this with an advanced search filter but I want to eventually extend this to encoumpass multiple Vaults.
I have watched a few of Dougs videos and have successfully logged into one of our servers and returned a list of the documents to a basic list box.
I now want to build on this to return only checked out files and the user names that have them checked out.
Can anyone point me in the right direction for more literature that can help me, I have found the 'IsCheckedOut' Property in the Vault SDK .chm file but apart from being discriptive theres no examples of its used for amatures like myself.
Ive wrote a few very basic C# and VB.net standalone applications.
Cheers
G
GrahamB8
Imports Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.WebServicesTools
Public Class Form1
    Private Sub button1_Click(ByVal sender As Object, ByVal e As EventArgs) Handles Button1.Click
        Dim cred As New UserPasswordCredentials("Servername", "Vault", "User", "Password")
        Using mgr As New WebServiceManager(cred)
            'Dim root As Folder = mgr.DocumentService.GetFolderRoot()
            'PrintFolder(root, mgr)
            Dim filePropDefs As PropDef() = _
                 mgr.PropertyService.GetPropertyDefinitionsByEntityClassId("FILE")
            Dim checkedOutPropDef As PropDef = _
                filePropDefs.[Single](Function(n) n.SysName = "CheckoutUserName")
            ' SrchOper 5 => is not empty
            Dim isCheckedOut As New SrchCond() With { _
                   .PropDefId = checkedOutPropDef.Id, _
                   .PropTyp = PropertySearchType.SingleProperty, _
                   .SrchOper = 5, _
                   .SrchRule = SearchRuleType.Must _
            Dim bookmark As String = String.Empty
            Dim status As SrchStatus = Nothing
            Dim totalResults As New List(Of File)()
            While status Is Nothing OrElse totalResults.Count < status.TotalHits
                Dim results As File() = _
                   mgr.DocumentService.FindFilesBySearchConditions( _
                    New SrchCond() {isCheckedOut}, _
                    Nothing, Nothing, False, True, bookmark, _
                       status)
                If results IsNot Nothing Then
                    totalResults.AddRange(results)
                    ListBox1.Items.AddRange(results)
                Else
                    Exit While
            End While
        End Using
    End Sub
End Class
This is where I have got to but the results in my List box are:
"Autodesk.Connectivity.WebServices.File"
wayne.brill
Below is an update to your code. It has a new For Each loop that adds the Name of the file and the name of the user who has it checked out to a list box.
It uses the Name property of the File and GetProperties with the File.Id and PropDef.Id to get the to the users name. (I tested using the VaultList SDK sample)
                       status)
                    'WB commented
                    'ListBox1.Items.AddRange(results)
                Else '()
                    Exit While
            End While
            'WB added
            Dim _File As File
            For Each _File In totalResults
                Dim propValues() As PropInst = mgr.PropertyService.GetProperties("FILE", New Long() {_File.Id}, New Long() {checkedOutPropDef.Id})
                Dim _CheckoutUserName As String = propValues(0).Val
                Me.m_listBox.Items.Add(_File.Name & "  " & "Checked out by" & "  " & _CheckoutUserName)
            Next
        End Using
    End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
GrahamB8
Thanks Wayne that was perfect!
ktelangCGFU6
The Serveridentity cannot be a string in usercredentials in new vault api . How to define serveridentity. I typically use VDF login to pass the user credentials. I am having tough time using that approach. can any body help
Markus.Koechl
The ServerIdentities class has two properties of type System.String: DataServer and FileServer. No change in the latest API.
You might leverage the API-Onboarding-ConsoleApp template in the SDK to get the full code for a WebService login.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
