Assign file to existing Item
mateusz_baczewski
mateusz_baczewski
I have the following problem: I’m trying to attach a file to an existing item. The code below executes without errors, and I can see from the date and time that the item was edited, but the file I specified was not attached. What could be causing this issue? I should add that the file I want to attach does exist.
 if (gridFileId != 0)
     File file1 = mVault.WebServiceManager.DocumentService.GetFileById(gridFileId);
     Item item = mVault.WebServiceManager.ItemService.GetLatestItemByItemNumber("SIATKA N6");
     if (item != null)
         var filter = ItemFileLnkTypOpt.Primary |
                      ItemFileLnkTypOpt.PrimarySub |
                      ItemFileLnkTypOpt.Secondary |
                      ItemFileLnkTypOpt.SecondarySub |
                      ItemFileLnkTypOpt.StandardComponent |
                      ItemFileLnkTypOpt.Tertiary;
         ItemFileAssoc[] assocByItem = mVault.WebServiceManager.ItemService
             .GetItemFileAssociationsByItemIds(new long[] { item.Id }, filter);
         var existingLinks = assocByItem?.ToList() ?? new List<ItemFileAssoc>();
         var primary = existingLinks.FirstOrDefault(a => a.Typ == ItemFileLnkTyp.Primary);
         var isPrimarySub = existingLinks.Any(a => a.Typ == ItemFileLnkTyp.PrimarySub);
         var secondaries = existingLinks
             .Where(a => a.Typ == ItemFileLnkTyp.Secondary)
             .Select(a => a.CldFileId)
             .ToList();
         var standardComponents = existingLinks
             .Where(a => a.Typ == ItemFileLnkTyp.StandardComponent)
             .ToList();
         var secondarySubs = existingLinks
             .Where(a => a.Typ == ItemFileLnkTyp.SecondarySub)
             .ToList();
         var tertiaries = existingLinks
             .Where(a => a.Typ == ItemFileLnkTyp.Tertiary)
             .ToList();
         if (!secondaries.Contains(gridFileId))
             secondaries.Add(gridFileId);
         long primaryFileId = primary?.CldFileId ?? 0;
         var editItem = mVault.WebServiceManager.ItemService.EditItems(new long[] { item.RevId }).FirstOrDefault();
         var updatedItem = mVault.WebServiceManager.ItemService.UpdateItemFileAssociations(
             editItem.RevId,
             primaryFileId,
             isPrimarySub,
             secondaries.ToArray(),
             standardComponents.ToArray(),
             secondarySubs.ToArray(),
             tertiaries.ToArray()
         mVault.WebServiceManager.ItemService.UpdateAndCommitItems(new Item[] { updatedItem });
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
Markus.Koechl
Hi @mateusz_baczewski, I understand you would like to assign your file as primary, correct? In this case, I suggest using the
PromoteComponents() method instead. For this approach, the target Item (existing) must have the Equivalence property assigned and filled; you can manually try the behavior settings before you do it programmatically.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
mateusz_baczewski
Hi @Markus.Koechl, no i would like to assing secondary file to item.
Markus.Koechl
Adding new files to an existing Item PromoteComponents() will automatically create a secondary link if a primary one exists. So, I'd prefer the same approach of leveraging a matching equivalence value for all link types. If your files to promote have documentation files, or design representation files (new in 2026 Update1) they will link (documentation) or attach (design representation) in the same process.
Anyway, if you have good reasons to follow your approach, the code should share a working sample to update associations (the sample moves secondary links to the standard component link type)
                    Item item = mVault.ItemService.GetLatestItemByItemNumber("ISO 10788-2 - 60 x 40 x 4");
                    item = mVault.ItemService.EditItems(new long[] { item.RevId }).FirstOrDefault();
                    ItemFileAssoc itemPrimAssoc = mVault.ItemService.GetItemFileAssociationsByItemIds(new long[] { item.Id }, ItemFileLnkTypOpt.Primary).FirstOrDefault();
                    ItemFileAssoc[] itemSecAssocs = mVault.ItemService.GetItemFileAssociationsByItemIds(new long[] { item.Id }, ItemFileLnkTypOpt.Secondary);
                    ItemFileAssoc[] itemStdAssocs = mVault.ItemService.GetItemFileAssociationsByItemIds(new long[] { item.Id }, ItemFileLnkTypOpt.StandardComponent);
                    List<long> secFileIds = itemSecAssocs.Select(n => n.CldFileId).ToList<long>();
                    List<long> stdFileIds = itemStdAssocs.Select(n => n.CldFileId).ToList<long>();
                    stdFileIds.AddRange(secFileIds);
                    long[] empty = new long[0];
                    item = mVault.ItemService.UpdateItemFileAssociations(item.RevId, itemPrimAssoc.CldFileId, false, empty, stdFileIds.ToArray(), empty, empty);
                    mVault.ItemService.UpdateAndCommitItems(new Item[] { item });
I hope this helps; I did not step through in detail your code - but I guess there is a minor (nasty) mismatch in the transfer of existing to new Ids.
Markus Koechl
mateusz_baczewski
Hi @Markus.Koechl ,
I really have no idea why this is happening. I cannot assign a file to an already existing item that already has a primary file. I would like to add to the item a file whose part number is the same as the item name. When I do this from the application level or using "Assign/Update item," everything works correctly, but when I try to assign it programmatically, the code executes properly without any errors, I can see that the item "TESTOWY_ITEM" was edited, but no new file was added as secondary.
When I try to add it this way, a new item with a strange name gets created. Most likely this happens because the vault does not allow adding two items with the same name.
 File file = FindFileBySearchCondidtions(vaultConnection, "PRO-000190406.ipt");
 long fileID = file.Id;
 if (fileID != 0)
     Item item = vaultConnection.WebServiceManager.ItemService.GetLatestItemByItemNumber("TESTOWY_ITEM");
     if (item != null)
         item = vaultConnection.WebServiceManager.ItemService.EditItems(new long[] { item.RevId }).FirstOrDefault();
         vaultConnection.WebServiceManager.ItemService.AddFilesToPromote(
             new long[] { fileID },
             ItemAssignAll.Default,
             false
         DateTime timestamp;
         GetPromoteOrderResults promoteOrder = vaultConnection.WebServiceManager.ItemService.GetPromoteComponentOrder(out timestamp);
         vaultConnection.WebServiceManager.ItemService.PromoteComponents(timestamp, promoteOrder.PrimaryArray);
         ItemsAndFiles promoteResults = vaultConnection.WebServiceManager.ItemService.GetPromoteComponentsResults(timestamp);
         vaultConnection.WebServiceManager.ItemService.UpdateAndCommitItems(promoteResults.ItemRevArray);
Markus.Koechl
Use the PromoteComponentLinks() method to assign secondary or documentation links. I added a sample to my collection: Vault-API-C#-Samples/Items/API-ConsoleApp-PromoteFileToItem/Program.cs. The sample requires two components with matching part number values. You can run the code once to create both link types in one go, or skip adding the secondary file in the first run and add it in the subsequent execution.
I hope this helps.
Markus Koechl
mateusz_baczewski
Hi @Markus.Koechl
Fantastic, this is exactly what I needed! Everything is working perfectly now. Many thanks!
