Job Processor 2026 command line /stop does not work anymore
JanInventor
JanInventor
When executing
C:\Program Files\Autodesk\Vault Client 2026\Explorer> JobProcessor.exe /stop
I get: "The command line argument "/stop" requires an already started Job Processor." while the Job Processer (2026) is running.
Same for /pause
When I close the job processor using Exit in the window this is working fine:
start JobProcessor.exe -w -s [servername]
When I repeat that I get the correct "Job Processor is already running", while the /stop is still not working.
See
https://help.autodesk.com/view/VAULT/2026/ENU/?guid=GUID-2D6ACAFC-7B43-4D0D-8A03-1D2B06F056DA
Is this a bug?
Markus.Koechl
It is a known issue in 2026 RTM that an upcoming update will address.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
luca_henniges
Fixed in 2026.1... 🙂
Luca Henniges
Application Engineer PDM/PLM
at
