IPropertyManager.GetPropertyDefinitions not working in Vault 2017
KarlR.J.Wehr
KarlR.J.Wehr
since upgrading to Vault R2017 the function GetPropertyDefinitions in Vault.Services.Connection.IPropertyManager is not working anymore.
I am using it in a Vault Extension. Calling the function results in a System.NullReferenceException exception.
This is the code i use:
Vault.Services.Connection.IPropertyManager pm = m_conn.PropertyManager;
Vault.Currency.Properties.PropertyDefinitionDictionary pdefs;
pdefs = pm.GetPropertyDefinitions
  Vault.Currency.Entities.EntityClassIds.Files,
  null
  Vault.Currency.Properties.PropertyDefinitionFilter.IncludeAll
In the stack trace i can see that the error occurs here:
    Autodesk.DataManagement.Client.Framework.Vault.Services.Connection.Implementation.PropertyManager.<>c__DisplayClass8_0.<GetPropertyDefinitions>b__0(PropertyDefinitionToEntityClassAssociation f)
The same code is working in a stand alone application but running in a Vault Extension it throws the above error.
Can anybody help me?
Karl
wayne.brill
Hi Karl,
Your code is working ok for me using the HelloWorld SDK sample. Below is a screenshot. Can you try this in HelloWorld? If your code does not work in HelloWorld either can you tell me about your system? What is the bitness and locale?
Also does using a different Vault make a difference?
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
