Inventor 2027.1 – Vault Data Standard is bypassed after cancelling Check In of an unsaved file
daniel_kuna
daniel_kuna
In Autodesk Inventor 2027.1 with Vault Data Standard 2027, there is an issue when checking in a new, unsaved file. The first time the Check In command is used, the Vault Data Standard dialog appears correctly. If the user selects No when prompted to save the file before checking it in, then runs Check In again and selects Yes, the Data Standard dialog does not appear again.
Instead, Inventor displays the standard Save As dialog. As a result, automatic numbering and the remaining VDS logic are bypassed. The issue also occurs with a completely default, unmodified Data Standard 2027 configuration.
Does anyone have this error?
Daniel
Markus.Koechl
Hi @daniel_kuna : please submit a support case for this. It does not relate to customization and we can't resolve here.
Thanks.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
