Get restrictions on Assign / Update Item
GabrieleZelasco
GabrieleZelasco
Good morning everyone,
in our solution (c#, Vault2023) I need to intercept the assign/update article call made by Vault 2023 starting from a cad file (by api of course).
In the event where I intercept the call, I should check the Part Number property if it meets certain requirements before the item is created and associated with the file.
If it does not meet these requirements, I would like to block the creation of the item adding restriction.
I have tried ItemService.PromoteItemEvents.GetRestrictions but it crashes the Vault, I assume because it works when updating an item and not a file.
Can anyone tell me which event or workaround I can use to achieve this ?
Thank you very much
GabrieleZelasco
Hi all. I was wrong about the ExtensionRestriction constructor:
public ExtensionRestriction(System.string objectName,System.string message)
If objectName is null then Vault crashes.
ItemService.PromoteItemEvents.GetRestrictions is what I needed.
It works starting from File and Item both.
I apologize. Thanks to all
