File Checksum on check-in
mchi_topsoe
mchi_topsoe
Using Inventor/Vault Pro 2024.
We have developed a custom job on job processor to generate view files (step & pdf) on check-in. But many times the users will check out files and check them in again, even though nothing has changed. In this case there should not be any need to generate a the view files once again.
1. Is there an out-of-the-box way to trigger if a given file has changed during check out, check in, which can be used in our job processor code to skip files that are not really modified?
Nick_Hall
Hi
My best suggestion is to use GetFilesByMasterId to get all versions of the file you are processing, and compare the Cksum of the latest version and the version previous to that
If they are different, the file has changed
Hope that helps
Nick
mchi_topsoe
But in that case I would still need to get the file in vault and calculate the checksum again. I don't see the value is stored in vault.
Nick_Hall
It’s in the CkSum property of the file version
You don’t need to download the files, just get the file versions and compare the two values of that property
Nick
