Excel Program to Open Drawings From Vault
Lauren_healey
Lauren_healey
I am writing an Excel program to run through a list of drawing numbers and retrieve information contained in those drawings. This information is contained as Sketched Symbols in these drawings. I assume the first step would be to locate the drawing in Vault and open it, but I'm not sure how to write an Excel program in VBA to do that. I am also wondering if I will have to install SDK first to write such a program?
Nick_Hall
Hi Lauren
That's not impossible using Excel VBA, but it is tough. This is a rough outline.
None of the above steps is easy individually; combining them is not for the faint-hearted.
I would approach it differently, using PowerShell to access Vault, Excel and Inventor. This would be easier to implement and more stable.
The PowerShell script would need to:
  • Connect to Vault
  • Open the Excel file and read in the list of drawings
  • Loop through the drawings, and
    • Locate the drawing in Vault
    • Download it to the local disk
    • Open it in Inventor
    • Use the Inventor API to find the sketched symbols
    • Write the data back to Excel
  • Save the Excel file
There are examples of using PowerShell to connect to Vault & Inventor in these forums, and to Excel in places like StackOverflow.
If this raises any questions, just ask
Hope this helps
Nick
Markus.Koechl
I suggested an alternative approach, as the major process is an Inventor task: use iLogic. It provides built-in Excel interaction, and the iLogic-Vault capabilities share all the methods needed to search, download, and open drawings from Vault.
Markus Koechl
Solutions Engineer PDM, Autodesk Central Europe
